Automatically log off SSL VPN users
Hello, is there a way to automatically log out the users of the SSL-VPN to the USG110 at a certain time? Unfortunately, there are always some users who no longer close the VPN tunnel (a maximum of 2 connections are allowed per user) and therefore always have to be logged off manually in order to be able to reconnect.
You can set each user with a lease time of 2 mins if they stay connected it renews if they close the VPN it logs then out after 2mins.
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
