USG 310/IPSec Error Packet(UDP) cannot be sent. reason: Network congestion
due to the current Homeoffice situation my company is running a lot more VPN Connections then usual.
Usually we are running about 6 or 7 IPSec IKE/IKev2 Site2Site Connections and about 5-10 IKEv2 Client2Site.
Now we have round about 20 additional Client2Site Connections and everything was running fine for 2 weeks until yesterday.
Suddenly some VPNs (S2S and C2S) disconnected and were unable to reconnect until we rebooted the firewall.
I noticed these Error in the Logs:
Any Ideas/suggestions?
Hi @WiSy
Do you enable BWM on the device?
When the issue occurred, can you disable BWM function and chek if the symptom is still exist?
5
Hi @WiSy
5 -
Hi @Zyxel_Jerry
I disabled BWM but issue still persists.
All IKE Site2Site get randomly dropped at the same time an are unable to reconnect until I reboot the Device.
IKEv2 Connections still working.
I noticed this entry in the log
Tunnel [IKE_NRW_Gateway:WISY-NRW:0x2c0aee2a] built successfully
41 2020-04-08 11:06:27 x.x.49.237:4500 x.x.184.39:4500
x.x.49.237 is the wrong IP for that Gateway, something is getting mixed up there.
Hi @WiSy
Can you collect diagnose info and IKE log when the log displayed “network congestion and send it to us via private message?
Here is the step to collect diagnose info.
Go to Maintainance > Diagnostics > Diagnostics > Collect > Click Collect now
After 5~10 minutes
Go to > Maintenance Diagnostics > Diagnostics > Files > Select the diaginfo > Click Download
Here is the step to collect IKE log
Go to Monitor > Log > View Log > select IKE category
Can you also provide remote access to the device via private message?
- 588 USG FLEX H Series
- 477 News and Release
