Max L2TP over IPSec concurrent connections on USG 100
Chris20
Chris20 Posts: 3 image  Freshman Member
edited April 2021 in Security
Hi, my USG100 firewall is properly connected site-to-site ipsec tunnel with a USG20.
No other active SSL connections.
In these days of COVID-19 I activated some users in L2TP over IPSec with windows 10. The first 3 users are able to connect correctly, the fourth appears this error:
If one of the first 3 users disconnects, then the other can connect.
Here https://mysupport.zyxel.com/hc/en-us/articles/360006999419--FAQ-Does-my-Zyxel-router-include-VPN-licenses- says that maximum connections are 50.
What could be the problem?
Thank you!
Chris
