Can USG310 resolve local server's name?
Hi SandB just a thought, if you cannot get a response from a host lookup for "landisk" for example instead of the FQDN hostname of landisk.bbb.cc ??
have you configured your local you domain name in the router? You can see this in the router by: show fqdn command or Web UI /Configuration/ System/ Host Name /Gen Setting ...
Router> show fqdn host name : acr-usg60-03 domain name: floor4.lab4 FQDN : acr-usg60-03.floor4.lab4
Suggest to test our properly , use another vanilla host on your LAN to try the DNS search or comment out the additions to your current host's /etc/hosts or its equivalent.
While you're there at the host or at the router check the reverse DNS as well.
Warwick
Hong Kong
5
Go to configuration>System>DNS>create the profile on Address/PTR Record> Fill FQDN with IP address
Thank you for reply.
For example, my hosts file is the following.
landisk 192.168.x.x
This landisk is not public. I can access landisk without IP in my LAN.
I enter "landisk" as FQDN and "192.168.x.x" as IP Address.
I cannot access landisk.
Please tell me how to setup my USG.
Warwick
Hong Kong
5
- 588 USG FLEX H Series
- 477 News and Release
