ZyWALL as a client connecting to a VPN server
PeterUK
PeterUK Posts: 3,799  Guru Member
edited April 2021 in Security
So I know how to do site to site and Remote Access (Server Role) but can't seem to setup the ZyWALL as a VPN client for say freel2tpvpn.com.
Or is it not possible?
  • Jeremylin
    Jeremylin Posts: 166  Master Member
    First Answer First Comment Third Anniversary
    edited April 2020
    It seems does not possible, since the VPN remote policy can't fill FQDN(fr.freel2tpvpn.com) on Zywall.
    Doing some testing theirs a bug for adding Enable Extended Authentication Client Mode with user name freel2tpvpn.com from saving as it has a dot.
    So I got my VM setup with Remote Access (Server Role) with the following on ZyWALL 110
    I then want to connect to that VPN over cellular1 on my VPN300 and this is how I set that up and the first problem is VTI does not allow Dynamic Address and the following does not connect.
