LTE firmware for SBG3600
  • HM4L69
    HM4L69 Posts: 1 image  Freshman Member
    My LTE connection doesn't work, like my simcard wasn't detected. I use a French connection.
    Could you send me the lasted firmware for my SBG3600NB ?
    Actual configuration :
    Firmware Version: V1.00(AAZE.9)
    LTE F/W Version: ALT3100_05_00_02_00_81_MS
    Thank you in advance.
    CMF
  • ChrisL
    ChrisL Posts: 1 image  Freshman Member
    Hi
    Please send latest firmware for my SBG3600, 4G speed is only 13/10M when similar device shows 50/35M.
    Software Version: V1.00(AAKO.9)
    Module Firmware Version: ALT3100_04_05_06_10_B8_LO
    Thanks!
    Chris
  • JuhRa
    JuhRa Posts: 2 image  Freshman Member
    Now when we really need latest updates and software, you are leaving us on the beach...
    If this is really support what we can even get it's super poor... Why you just can't share download links in product page? This will be my last Zyxel product and I will not recommend them to my clients. ☹️
  • Markus
    Markus Posts: 1 image  Freshman Member
    Could you send LTE firmware update link for me too? Little problems with modem and I think LTE firmware update could be the solution. Thanks.
  • Bob_C
    Bob_C Posts: 222 image  Master Member
    Hi JuhRa,
    Your firmware combination is already the latest.
    Regards,
    Bob
  • Bob_C
    Hi Tom_W0lfs,
    May I know which router and LTE firmware you're using?
    Regards,
    Bob
  • TINT
    TINT Posts: 2 image  Freshman Member
    edited April 2020
    Hello Zyxel_Bob,
    i have performance issue on LTE, Cay you provide me firmware ?
    My firmware is
    Thank you.
    Regards.
    Tom
  • TINT
    edited April 2020
  • Bob_C
    Hi Tom,
    I've sent a private message. Please check your inbox.
    Thank you.
    Regards,
    Bob
  • Levente
    Levente Posts: 9 image  Freshman Member
    Hi Bob,
    Please share it with me as well.
    Thanks!
