Authorization on AD group for L2TP does not pass
Niviteka
Niviteka Posts: 17 image  Freshman Member
edited April 2021 in Security
Zywall 310 / fw 4.35 (AAAB.3)
For L2TP users, a local group (L2TP-VPN-users) in Zywall has been created, where those who are allowed access to VPN (allowed users) are placed.
AD authentication was configured, an ad-users internal user was added to the L2TP-VPN-users group. As a result, all users of the domain and local are authorized and connected.
But as soon as you try to allow authorization only for users belonging to a certain AD group (ext-group-user). Authorization fails ("disallowed user" in logs)
Group authorization is as follows - An AD-VPN user of the ext-group-user type is created. with settings defining the AD group. When testing inside the ext-group user test, the test passes - the status is OK.
The created user (AD-VPN) was added to the VPN allowed group (L2TP-VPN-users), and the ad-users built-in user was removed from the allowed group. After that, authorization through AD does not work.
  • Niviteka
    After update the newest weekly firmware  (V4.35(AAAB.3)ITS-WK13-r92843) problem was solved.
  • Zyxel_Charlie
    Zyxel_Charlie Posts: 1,034 image  Zyxel Employee
    @Niviteka
    As your description,
    can you check the account on AD is enabled?
    Also, can I know do you login to the device GUI successfully via account?
  • Niviteka
    Account enabled.
    I can to login to the device GUI successfully via AD account.
    I can even connect to L2TP if I add the ad-user to the L2TP-VPN-users group, but then all domain users can join VPN.
    I need so that only users of the VPN-users group in AD can connect to VPN.
  • Niviteka
