Authorization on AD group for L2TP does not pass
Zywall 310 / fw 4.35 (AAAB.3)
For L2TP users, a local group (L2TP-VPN-users) in Zywall has been created, where those who are allowed access to VPN (allowed users) are placed.
AD authentication was configured, an ad-users internal user was added to the L2TP-VPN-users group. As a result, all users of the domain and local are authorized and connected.
But as soon as you try to allow authorization only for users belonging to a certain AD group (ext-group-user). Authorization fails ("disallowed user" in logs)
Group authorization is as follows - An AD-VPN user of the ext-group-user type is created. with settings defining the AD group. When testing inside the ext-group user test, the test passes - the status is OK.
The created user (AD-VPN) was added to the VPN allowed group (L2TP-VPN-users), and the ad-users built-in user was removed from the allowed group. After that, authorization through AD does not work.
After update the newest weekly firmware (V4.35(AAAB.3)ITS-WK13-r92843) problem was solved.
@Niviteka
As your description,
can you check the account on AD is enabled?
Also, can I know do you login to the device GUI successfully via account?
Account enabled.I can to login to the device GUI successfully via AD account.I can even connect to L2TP if I add the ad-user to the L2TP-VPN-users group, but then all domain users can join VPN.
I need so that only users of the VPN-users group in AD can connect to VPN.
- 394 Beta Program
- 2.1K Nebula
- 117 Nebula Ideas
- 5.1K Security
- 82 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 914 WirelessLAN
- 34 WLAN Ideas
- 5.9K Consumer Product
- 209 Service & License
- 337 News and Release
- 71 Security Advisories
- 21 Education Center
- 2K FAQ
- 908 Nebula FAQ
- 415 Security FAQ
- 236 Switch FAQ
- 207 WirelessLAN FAQ
- 46 Consumer Product FAQ
- 138 Service & License FAQ
- 73 About Community
- 62 Security Highlight
