USG110 Blocking RDP in LAN
We've got RDP working here. As long as you don't leave your local LAN segment, the USG isn't blocking anything. Only when changing the Zone (e.g. access from LAN1 to LAN2), the USG is filtereing the traffic and you have to set some rules.
Very strange, both server and clients are on LAN1
also noticed that software on clients that use SQL on server doesn´t work
Have you got any Domain Controller in place where Group Policy Objects (GPO) deny RDP connections? Did you checked the RDP settings at your local machines? Is it activated and access permissions for the particular user available?
It used to work with our old D-link, the setting are ok att all machines
i got this Zyxel in my knee when the other broke down, ready installed for our business.
it also have VPN connection to our other site, everything works but not RDP and SQL in our LAN1 (192.168.3.xxx) other site (192.168.1.xxx)
must be something that blocks some ports or something
Then you would like to use RDP over two network segments 192.168.3.x and 192.168.1.x. This is not inside the same LAN!
For using RDP over different zones you have to allow Port 3389 (TCP/UDP) in the Security Policy Control of the USG.
USG_User said:Then you would like to use RDP over two network segments 192.168.3.x and 192.168.1.x. This is not inside the same LAN!
So its in the same LAN
I did a Scan with an IP-Scanner app
at the server IP adress and the ports 80. 3389, 1433 ( think theese at default ports for RDP and SQL )
and only 80 is open, our server Also have IIS webserver for our local intranet and it works
Are you RDP from remote or local?0
Problem solved !
Windows Fu%"#ing firewall
Can´t understand why it´s blocking now after switching to the Zyxel0
- 415 Beta Program
- 2.4K Nebula
- 151 Nebula Ideas
- 98 Nebula Status and Incidents
- 5.7K Security
- 277 USG FLEX H Series
- 277 Security Ideas
- 1.4K Switch
- 74 Switch Ideas
- 1.1K Wireless
- 42 Wireless Ideas
- 6.4K Consumer Product
- 250 Service & License
- 395 News and Release
- 85 Security Advisories
- 29 Education Center
- 3.6K FAQ
- 75 Security Highlight
