Thank you Jeremylin!!!
Vpn ipsec - client to site with USG20 - tunnel is up but can't ping subnet site
Antonio967
Good morning,
I have configured a vpn ipsec client to site on USG20, on my pc I have installed ZyWall ipsec vpn client (IKE V1), the tunnel opens but I cannot ping the subnet.
Thanks for the help.
Try to disable server's firewall(under Zwall).
Do the IP address of Ipsec VPN client overlap with IP of server?0 -
By deactivating the Windows Firewall I reach the remote subnet.In the Windows Firewall I had opened ports 500 and 4500 but obviously something was wrong, would you know how to configure it correctly so that you don't have to disable it?
Thanks for the help!!!0 -
Why did you open ports 500 and 4500. These ports are used for vpn reasons. Your vpn is operating between your firewall and the remote pc (or laptop). There is no reason to open these ports. What di you want to do exactly? Remote desktop for example?0
I also curious why you want to open the ports you mentioned.
Anyways, go to windows firewall with advanced security to customize profile.
As your reference
https://www.howtogeek.com/howto/windows-vista/allow-pings-icmp-echo-request-through-your-windows-vista-firewall/
Thanks Jeremylin and Alex00,
i have to access shared folders on a PC but also in remote desktop it would be convenient for me.I thought ports 500 and 4500 were the reason I didn't reach the internal network, but you are right, they actually have no reason to be opened in the windows firewall.Unfortunately, however, since yesterday even with windows firewall disabled I don't ping and I don't reach the subnet, I haven't made any changes, I simply don't reach the subnet anymore ...Tunnel open, windows firewall off but I don't reach the subnet...
Thanks for the help!0 -
Change PC(under Zwall) with disabled firewall and test it again.
Make sure the IP of server's firewall(under Zwall) is not the same as PC's.
- 438 Beta Program
- 189 Nebula Ideas
- 6.2K Security
- 465 USG FLEX H Series
- 304 Security Ideas
- 81 Switch Ideas
- 281 Service & License
- 440 News and Release
- 4.3K FAQ
- 93 Security Highlight
