ADSL Connection to VES1724 DSLAM
I have a DSLAM setup on my site and have it connected to some VDSL2 modems. All good.
However, I am trying to connect a couple of ADSL modems, and this is not working.
I have been through the documentation, and I believe I have everything setup correctly, but I am getting noPeerAtu error, followed by commFail on the port.
The modem is a TP-Link TD-W8961N ADSL2+ modem and I have it setup as follows:
VPI 8
VCI 35
ATM QoS UBR
Dynamic IP
Encapsulation 1483 Bridged LLC
Bridge Interface Deactivated
NAT Disabled
I have the following config on the VES1724
ADSL Fallback:
Port 1
VPI 8
VCI 35
PVID 1
Encap LLC
Priority 0
FCS no FCS
MVLAN Disable
VLAN 802.1Q
Port 1 set to Fixed with Tx Tagging
Port 25 set to Fixed no Tx Tagging
VLAN Port Setting
Line 1 PVID set to 1
VDSL Line Profile
VDSL Profile 17a (I have to choose something)
Transmission mode G.993.2 Annex A
ADSL/VDSL profile
I think that covers everything.
Any suggestions would be appreciated, as I have tried everything I can think of.
Thanks, Ross
VPI 8
VCI 35
ATM QoS UBR
Dynamic IP
NAT Disabled
ADSL Fallback:
Port 1
VPI 8
VCI 35
PVID 1
Encap LLC
Priority 0
FCS no FCS
MVLAN Disable
VLAN 802.1Q
VLAN Port Setting
VDSL Line Profile
ADSL/VDSL profile
G.992.1A G.992.1B G.992.2A G.992.3A G.992.3B G.992.3I G.992.3M
G.992.5A G.992.5B G.992.5I G.992.5MI think that covers everything.
Thanks, Ross
Hi Ross,
For TP-Link TD-W8961N, Dynamic IP, Bridge Interface Deactivated and NAT Disabled. so the ADSL2+ modem is configured as IPoE WAN with NAT disabled?
Based on your description looks the DSLAM configurations are correct, may I know if you faced the DSL link up but traffic not pass through? or even the DSL link is not link up?
Does the uplink port 25 also with PVID 1?
Hi Nikki,
The DSL Link does not come up if with the ADSL modem. It does work with the VDSL modem though.
The configuration problem seems to be the ADSL setup somewhere. I have tried various configurations, but no luck.
Do you know if this device even works with ADSL?0 -
Hi Ross,
From the information I got, this device is support fallback to ADSL.
Maybe you could try to contact with ZYXEL local support to get latest version (not sure which version you are using), and could also try with select G.992.5A only.
Hi Ross, Just wondering how you got on with this setup to allow ADSL devices to connect to the VES1724 VDSL Dslam?
We have the same situation with a conversion to VDSL for a site and keen to know if we can do this or we have to also replace all modems ?
Thanks Shane0
- 441 Beta Program
- 294 Service & License
- 461 News and Release
