Question regarding Phase 1/2 Settings for multiple Site2Site VPNs
Im getting told (by Zyxel Staff) to use diffrent Phase 1/2 Proposal for multiple Site2Site VPNs to avoid Problems
The following Screenshot shows the current Situation.
Phase 1
Phase 2
My Problem:
Im not really sure how to set up diffrent Encryption/Authentification Settings without compromising security.
It would really helpfull if someone could provide me an example how to set this up properly.
Best Regards
Fabrice
@WiSy
Regarding to this case,
you can configure Local/Peer ID to separate the multiple site to site VPNs.
Also, for the Encryption/Authentication setting, we suggest to use AES128/SHA1 as algorithm.0
- 220 Nebula Ideas
- 608 USG FLEX H Series
- 299 Service & License
- 482 News and Release
