Unsupported MacOS
tomdyglen
tomdyglen Posts: 1 image  Freshman Member
edited April 2021 in Security
I am running Mac OS version 10.15.5 and am being advised that ZyWall SecuExtender cannot start as it does not support this version. Do you have an update.
  • Zyxel_Charlie
    Zyxel_Charlie Posts: 1,034 image  Zyxel Employee
    edited April 2020
    @tomdyglen
    The current official Mac OS release is 10.15.4 which is supported by the Secuextender V1.1.9
  • dpipro
    dpipro Posts: 73 image  ZCNE Certified
    First Comment Friend Collector Seventh Anniversary ZCNE Switch Level 1 Certification - 2020
    edited April 2020
    Hello Charlie,
    Secuextender V4.0.3.0 is for windows, right? I have the same issue, I can´t install SecuExtender on Mac OS 10.15.4. Thank you
    Best regards
  • Zyxel_Charlie
    edited April 2020
    @dpipro
    Yes, you are right. The Secuextende V4.0.3.0 is for windows. Can I know did you install SecuExtender V1.1.9 on Mac OS 10.15.4?
  • dpipro
    @Zyxel_Charlie
    OK, I will try to download it. I will give you feedback
    Thank you :-)
    Best regards
