What description will be displayed, if website be blocked
This discussion was created from comments split from: ATP200 Content Filter.
Sorry my ATP is not installed yet but I have a question.
I want to give Free Wifi for my Guests and block "bad" Sites.For example "Nudity". Do you know what when a News Website have Nude Contend on there Page what happen?Is there a way to show the User why the Page is blocked like: "This Page is blocked for Nudity."Thanks
@Username_is_reserved
If you configure safe search on content Filter, ex: Nudity or Pornography/Sexually Explicit.
After you access the related websites, some of web pages will display as below
some of pages will be blocked directly(No description).
However, all you can check ATP's log message to know which category was hit.
wow can i config this Page to my own Style? I run a Proxy to will will block some thins and both should look like identical. (Well I am happy to see what kind of Sites Zyxel Employee know.)I saw I can make different Filter for different User Groups. Thats good for that.Thanks
I found it! ATP -> Web Authentication ->Internal Web Portal Customize FileCan I change there the HTML Files to show a different Style?
The page is standard style, and it cannot be customized.
As you mentioned, the customized file from web authentication which is for captive portal function is not related with CF's block page.
However, I would like to add your request to Idea.
Once the ideas get lots of Likes, we will give it to our product developers to have them evaluated and tell you the feedback.
Thanks that would be nice.
- 395 Beta Program
- 2.1K Nebula
- 116 Nebula Ideas
- 78 Nebula Status and Incidents
- 5.1K Security
- 51 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 70 Switch Ideas
- 907 WirelessLAN
- 34 WLAN Ideas
- 5.9K Consumer Product
- 210 Service & License
- 332 News and Release
- 71 Security Advisories
- 21 Education Center
- 1.9K FAQ
- 880 Nebula FAQ
- 415 Security FAQ
- 221 Switch FAQ
- 195 WirelessLAN FAQ
- 46 Consumer Product FAQ
- 137 Service & License FAQ
- 72 About Community
- 63 Security Highlight
