Block Teamviewer
Machiko
Machiko Posts: 3 image  Freshman Member
edited April 2021 in Security
Hi, I have a Firewall USG-310 and I need to block access to Teamviewer only for the countering computers. Can I set this up?
    TeamViewer use TCP and UDP connections over port 5938 so guess you can block that.
    Are you trying to blocked it for remotely to local or locally to outbound?
  • Machiko
    locally to outbound
    So yes make two service with TCP 5938 and UDP 5938 (you can then group in TeamViewer) then in policy control have rule from LAN1 to WAN with group TeamViewer for service and deny.
  • Machiko
    Thank you very nicely, I'll go so set up.
