Remote management from a specific fixed ip
Make a address object for the given IP then add a Policy control with from WAN to ZyWALL with source being your given IP object.
Thanks Peter for the reply, all good there.
I have another question if u do not mind, is there way to lock down the admin account only to be
accessible from the internal ethernet network 192.168.xxx.xxx but not when i connect via wifi.
BR
Andreas0 -
In system > WWW you can lock it down to a given IP
So if i want to restrict my admin account to access all the functions only via the available Lan interfaces I create 2 rules -> zone: Lan1_subnet and Address: ALL and Lan2_subnet and Address: ALL with both to have action as accept, and then change the default rule to Zone: All , Address: ALL to deny ?
Sorry i am double checking but i do not want to lock myself out
Andreas0 -
Yes I think you get it but you can't change the default rule which is why you make a rule for deny but backup your config.
You also need a rule for zone wan if your going to connect remotely.0
- 220 Nebula Ideas
- 607 USG FLEX H Series
- 482 News and Release
