View activity on address objects
CompuSoft
CompuSoft Posts: 4 image  Freshman Member
edited April 2021 in Security
We've got an api that creates address object and places them in an address group which has a NAT rule.
What I would like to know is if its possible to view which address object that are hit within a certain range of time.
So is it possible to pull this information out of the Zyxel USG1100?
Since the device only handles 2000 objects and we've got a bunch of "dead" objects (we just don't know which ones) we would like to locate these and delete them.
Best regards
CompuSoft
  • Zyxel_Charlie
    Zyxel_Charlie Posts: 1,034 image  Zyxel Employee
    edited November 2017
    Hello CompuSoft,
    If you want to know which address object is used or not, check up reference filed on address list.
    When the value of reference is 0, which means it’s a “dead” object. Also, the “dead” objects can be deleted at once.
    Charlie
  • CompuSoft
    Hi Charlie,
    Thank you for your response, unfortunately its not that kind of "dead" objects that I meant.
    We have alot of hosting customers that can whitelist their own public ips in our firewall thru our API, so that they can access thir hosted server.
    Unfortunately some of them are on dynamic ips and when they get a new ip they whitelist that one but the old one still remains.
    So I was looking for a way to see if a certain ip still tries to connect to our firewall, and if it haven't connected during 2-3 weeks then I could delete the address object associated with that IP.
    PeterUK Posts: 4,411 image  Guru Member
    Maybe you could use the log to see what ones are active to ones that are not?
