USG20W-VPN: Problems establishing Wifi connection / spontaneous reboots
@Zyxel_Charlie
Thanks for your feedback. I installed the firmware you sent me via private message and copied the same amount of data which I did before (which caused the router to reboot). This time it worked without any problems. I managed to copy an amount of around 10GB without any problems.
As while logging into my router I got the announcment for 4.38(ABAR.0) which was released recently, I also tested it with this version. I can confirm that 4.38(ABAR.0) still triggers the bug.
When will the bugfix be part of the official release?
Zyxel_Charlie said:0
@janatajan
Regarding to the USG20W-VPN issue, you can download the current patch from the link below
Link:
https://drive.google.com/file/d/1sgF6Je59SCMw0fVToSfUYcDykGLSHGD0/view?usp=sharing
getting firmware installed, my kids keep complaining that wifi goes away and the only thing that get it live again is a power cycle. I also have laptop cooling fan connected to USB just to make it cozy and we have to power cycle about twice a week... this started to happen about a year after purchase and I only update firmware when there is an issue... so maybe this patch v4.38 will do the trick0
janatajan said:Client is furious and I have to buy another device to replace this USG20W-VPN
At $200-250 20W price is ok, next up 40W $400, 60W $600 and so on just gets way out of reach for customers--and could you imagine if those models had firmware issues... ouch that would not look good on US and a quick way to look for other brand.
I would like to continue to purchase and install the 20W but these issues related to firmware and Wifi just have to stop---either that or I am going to purchase non wireless box and install reliable APs as I was doing before.0 -
Hi @Rigo
It’s good to know it has fixed your issue.
This fix will also include in next FCS version which will release at Q3.
- 398 Beta Program
- 2.1K Nebula
- 117 Nebula Ideas
- 83 Nebula Status and Incidents
- 5.2K Security
- 99 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 922 WirelessLAN
- 35 WLAN Ideas
- 5.9K Consumer Product
- 212 Service & License
- 337 News and Release
- 71 Security Advisories
- 21 Education Center
- 2.1K FAQ
- 1K Nebula FAQ
- 445 Security FAQ
- 238 Switch FAQ
- 213 WirelessLAN FAQ
- 47 Consumer Product FAQ
- 142 Service & License FAQ
- 72 About Community
- 62 Security Highlight
