NTP Service (Server) on USG for SOHO Devices
ChrisGer
It would be great, if the USG can also serve a NTP Sever functionality and the USG is the Device to sync the local time with NTP-Server in the extranet for small/remote offices.
Benefit: no additional time server is required and the USG can serve correct date/time to domain ad client systems during a broken extranet connectivity
7
And I am also waiting for such feature! It would be great if USG can be the time source in the LAN.
+1
A very beautiful implementation like pfSense would be very nice! Listening on every chosen interface so that the according VLAN's default gateway can be used as NTP server.0 -
+1 This would be very helpful.0
+1 Please add this feature.0
Are the new FLEXxxxH series devices NTP servers?
Hi @Wojtek ,
The FELX H series support enable NTP server via CLI.
> edit running running config# / vrf main ntp server-subnet 1 allow {<A.B.C.D/M> | all} running config# commit running config# copy running startup running config# exitBut there an minor issue in current version. The CLI settings for NTP server will be clean if apply system settings on GUI. Will fix in Q1, 2024 release.
Good news, thank you very much. :)
Will NTP be available via GUI in the future?
Sorry, no plan at the moment of the GUI design.
Plans are likely Q3 2024.
Thank you for the information.
- 588 USG FLEX H Series
- 477 News and Release
