ATP200 - Where are the Firewall Settings?
Username_is_reserved
Hi
Currently I use my USG300 and the should be replaced with the ATP200 who I try to config now.
But where the hell are the Firewall Settings to allow/ block Ports like in the USG?
Thanks!
Thanks!
@Username_is_reserved
Regarding this case, for example, block from wan to lan with port:8881
Go to configuration>Object>Service>Add
Then Go to Security Policy>Policy control>Add, Form Wan to Lan ,Port:B_port,Action: deny
HiOn my USG300 It look like that:
https://kb.zyxel.com/KB/searchArticle!viewBlob.action?attOid=3709So all Ports are blocked by default (like how it should be)?
But by default in your link above show allow for the bottom default rule0
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
