Next-hope vpn2s
How to select next-hop mode on vpn2. This menu is not available in policy settings.
https://prnt.sc/s9afuo
@Anglsmit
Currently, the VPN2S does not support Next Hop function for IPSec VPN tunnel.
However, I would like to add your request to Idea.
Once the ideas get lots of Likes, we will give it to our product developers to have them evaluated and tell you the feedback.
@Anglsmit
If you need certain feature urgently, you may consider USG20-VPN to fulfill your requirement.
Spec as your reference.
https://download.zyxel.com/USG20-VPN/datasheet/USG20-VPN_10.pdf
I already bought vpn2s. How then should I configure routing in ipsec. The main branch is zywall 110. The second office also uses zywall 110. And now I bought vpn2s in the third office and I don’t know how to configure routing.
- 440 Beta Program
- 292 Service & License
- 4.6K FAQ
