limited number of objects ?
I have a list of 1000 ip addresses to block. When trying to add them via cli (address-object ip_1_2_3_4 1.2.3.4) i am getting the following error message: -->
ERROR: The address-objects have reached the maximum number.
It seems like usg20 is limited to maximum 200 address-object?
if there a different way to achieve my need?
Regards,
Regards,
You need bigger USG or maybe managed switch.
If these IP addresses belong the same subnet or range, you can add address object by selecting address type "range" or "subnet" instead of "host".It may reduce the number of created address object.1
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
