vpn client and nat server
2»
  • antonellobellisario
    antonellobellisario Posts: 17 image  Freshman Member
    edited May 2020
    but to connect from the remote client do I have to use Ipsec VPN client
    and then to make join to domani?
  • Zyxel_Jerry
    Zyxel_Jerry Posts: 1,406 image  Zyxel Employee
    edited May 2020
    Hi @antonellobellisario
    Do you mean that you want to build up a vpn tunnel to the device with the AD server users to login?
    Can you describe more details about your scenario?
    this scenario
    can i use secure extender for connect ?
  • Zyxel_Jerry
    Hi @ antonellobellisario
    Yes, it can use SecuExtender to build up SSL VPN tunnel to login USG AD users.
    Below is the example settings
    Go to Configuration → Object → AAA Server > select the already created "AD" profile and click Edit.
    At the bottom of the settings, you can test your account on "Configuration Validation" field.
    To make the USG look in the Active Directory
    Go to the Configuration→ Object→ Auth. Method> Edit the default rule.
    Add group ad in to the settings
    Create a ext-group-user
    Go to Configuration→ Object→ User/Group
    Setup SSL VPN settings
    Go to Configuration > VPN > SSL VPN > Click “Add” to add a new rule
    Then can use SecuExtender to build SSL VPN tunnel to the device
    Here is the link of related discussion article on forum
    https://businessforum.zyxel.com/discussion/1002/ad-validated-users-ssl-vpn
  • itxnc
    itxnc Posts: 102 image  Ally Member
    First Comment Friend Collector Seventh Anniversary
    If you're just trying to VPN into a domain managed LAN, that LAN is using the domain server for DNS as well, correct? If so, can't you just do something like this: https://businessforum.zyxel.com/discussion/4207/how-to-force-dns-query-pass-into-ssl-vpn-tunnel
    To force the remote system's DNS through the VPN to the domain server? Then you should be able to join the domain and resolve NetBIOS names, etc.
    when I try the user
    i see the message
    "vpn" does not belong to this group.
    what am I doing wrong?
  • Zyxel_Jerry
    edited May 2020
    It means that the user is not belong to the group on your AD server,
    It need to add the user into the group.
    Here is link of related setting on AD server
    https://kb.zyxel.com/KB/searchArticle!gwsViewDetail.action?articleOid=014994&lang=EN
    the configuration is correct but always this message:
    "users" does not belong to this group.
  • Zyxel_Jerry
    Can you have a check which organization is the “vpn “ user belongs to?
    If the user is under different organization, it will not detect the user.
    Here is the related example,
    Add a user named “usera” in below domain “USG.com”,
    And the “usera” is under the organization “CSO” and it belongs to the group “CSO-test
    When setup the ext-group-user setting on USG
    If set group identifier as CN=test_group,CN=Users,DC=usg,DC=com,
    The Test Status will display “usera” does not belong to this group”.
    Since the “usera” is not in the organization “Users”, it is in the organization “CSO”
    The identifier should setup as “CN=CSO-test,OU=CSO,DC=usg,DC=com
    Then check the Test Status on the device, it will display “ OK “.
