USG300 - How to make a DSL Connction?
Username_is_reserved
OMG where is my Post goes....
Again...
I never used a DSL Connection and I dont know how to set that up.
My Provider give me that Information:
User ID + PW
VDSL2
VLAN-ID: 31
Protokoll: PPPoE
Where should/ have I put the VLan ID in?
I forced them to give me a Zyxel Modem! https://www.zyxel.com/us/en/products_services/VDSL2-17a-Bonding-and-35b-Single-Line-Bridge-VMG4005-B50B/downloads
I know I can/ have to set it up at:
Network -> Interface -> ppp
Can I should do something wrong?
There're many steps to configure for that.
Here what's I found from Zyxel KB, FYI.
https://support.zyxel.eu/hc/en-us/articles/360001390334-Setting-up-a-VLAN-on-a-WAN-PPPoE-Interface
@Username_is_reserved
Go to Configuration>Object>ISP account, and fill PPPoE's Account/Password.
Create the Vlan interface, and Go to PPP>Base Interface select Vlan profile and choose the ISP account you created.
Ian31 said:There're many steps to configure for that.
https://support.zyxel.eu/hc/en-us/articles/360001390334-Setting-up-a-VLAN-on-a-WAN-PPPoE-InterfaceThanks that work perfect. I wonder hat the work.
Its weird the Main Page show me the correct Adress but the "Interface Status" show me a different IP.Well I dont care since my IP is the WAN one.Another think I need to fix is the DSL Connection is only for some Service not for Surfing the Web.Sure I can block the traffic by the FW but the should not get there for the normal User.
I know: Configuration > Network > Interface > TrunkSo what should be routed via the DSL Connection is:
a) a VoIP Phoneb) some Service for some Portsc) a Internet (HTTP, Mail,...) Traffic for 2 IP Adress if the main Cable Connection fail fails.Is there a easy way for that? Well a Policy Route?
Thanks0 -
If you want to limit only some service go through indicated interface.
Go to object to customize service or port to be group. Create the account which will be controlled.
Go to routing, and set as below
Failover for internet, just add two wan interface in the customized profile on trunk page0
- 243 Nebula Ideas
- 6.9K Security
- 793 USG FLEX H Series
- 391 Security Ideas
- 88 Switch Ideas
- 59 Wireless Ideas
- 7.3K Consumer Product
- 327 Service & License
- 530 News and Release
- 104 Security Advisories
- 5.4K FAQ
- 91 About Community
- 122 Security Highlight
