Usg 50 3.30(BDS.9) cannot connect using VPN L2TP IPSEC
ITS
ITS Posts: 16  Freshman Member
edited April 2021 in Security
Hi, I cannot connect anymore using windows 10 or android device on L2TP/IPSEC. If I use Secure extender I can connect with SSL VPN.
If I run connection i still se on windows "connecting". On zywall VPN Monitor show L2TP_VPN_Connection connected but on log I see 2 strange row:
1st:
error
IPSec
SPI: 0x49d36825 (1238591525) SEQ: 0x1 (1) No rule found, Dropping ESP/NAT-T packet
2nd:
notice
Firewall
Match default rule, DROP ACCESS BLOCK
Any suggest to solve this problem?
Thanks Francesco
  • Zyxel_Stanley
    Zyxel_Stanley Posts: 1,397  Zyxel Employee
    100 Answers 1000 Comments Friend Collector Seventh Anniversary
    Hi @ITS
    We have fixed similar IPSec issue for legacy model, I will send firmware to you by private message.
  • ITS
    edited March 2020
    sorry, duplicated
  • mMontana
    mMontana Posts: 1,432  Guru Member
    @Zyxel_Stanley There's any way to publish all the "latest patched firmwares" for legacy models?
  • ITS
    Unfortunately Stanley sent me a dropobox link but I never received a notification, and now link ha expired. I asked to Stanley via PM to send me it again, but nothing at the moment.
  • Zyxel_Stanley
    Hi @ITS
    I have sent a new link to you again. Please have a check your mail box.
  • Daiana
    Daiana Posts: 3  Freshman Member
    I have a zywall 50 router/firewall and I have this error  "SPI: 0x49d36825 (1238591525) SEQ: 0x1 (1) No rule found, Dropping ESP/NAT-T"
    Please send me the latest firmware update.
    Thanks,
    Daiana
  • Daiana
    Thanks a lot,
    Daiana
  • Daiana
    Hello again,
    I am trying to upgrade the firmware, but  the message "Firmware upload in progress" never finish.
    Please help
    Daiana
  • Zyxel_Charlie
    Zyxel_Charlie Posts: 1,034  Zyxel Employee
    @Daiana
    Regarding to this case,
    after updated the firmware for a while, did you refresh the browser page? and can I know was the sys LED still blinking?
    Do you have console cable to connect device?
