[NEBULA] Disconect Reason definitions
Is there a list of disconnect reasons for a client disconnecting from an AP? Also -- any documentation on Event Log detail? I get the following message: "Netconf connection is disconnected. Relevant to Gateway is unavailable." not sure what it means.
Hi @RichP,Please refer to the relevant reason codes of deauthentication/disconnection as below link:https://businessforum.zyxel.com/discussion/4430/what-is-the-meaning-of-wireless-802-11-deauthentication-reason-codes/p1?new=1
Netconf is a protocol which is used by AP and NCC(Nebula Cloud Center) to communicate with each other. However the log means Netconf protocol connection is disconnected at that time and AP can not ping to its gateway, so it instructs the gateway is unavailable.
Hope it helps
Best regards,
Panda0
- 3K Nebula
- 222 Nebula Ideas
- 619 USG FLEX H Series
- 349 Security Ideas
- 53 Wireless Ideas
- 485 News and Release
