Seeing port scans on a LAN device when no NAT/etc is set up.
USG110
Default(ish) setup, with a Netgear Orbi sitting on lan1 port. The Orbi keeps showing these log lines:
The only non-default config is the definition of a host object, and a policy allowing:
host -> zywal (IP:any/any) for HTTPS to allow remote management of USG from one specific location.
Will welcome any ideas as to how the ORbi gets scanned while sitting behind a firewall.
[DoS Attack: ACK Scan] from source: 17.248.147.83, port 443, Wednesday, May 13, 2020 10:56:59 [DoS Attack: ACK Scan] from source: 17.248.147.108, port 443, Wednesday, May 13, 2020 10:50:08 [DoS Attack: ACK Scan] from source: 74.125.206.128, port 443, Wednesday, May 13, 2020 10:50:04 [DoS Attack: ACK Scan] from source: 17.248.147.45, port 443, Wednesday, May 13, 2020 10:49:29But no NAT or similar rule has been set up.
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
