Unable to create or update Reports
Whenever I try to create a report, I get this message
"Unexpected exception: Direct assignment to the forward side of a many-to-many set is prohibited. Use widgets.set() instead"
The report is created but without any widgets enabled. And I receive empty reports.
Trying to update the report configuration leads to the same issue :
Deleting, recreating the reports doesn't solve the issue.
So I have been receiving empty reports for weeks now.
What's wrong with the config ?
Thanks for your help.
Thierry
Thierry
We have confirmed this issue internally, and it will be solved asap.
Sorry cause you inconvenience.
5
5 -
Thank you ! It works fine now.0
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
