Some SSL VPN drop everyday at the same hour
Hi. I've a little problem with VPN. We have a USG 110 with latest firmware 4.38(AAPH.0). On WAN1 we have a FTTC (unfortunatly just 60/6 mbps) router, instead on WAN2 we have an antenna (30/3) with PPP connection. Both WAN are in a trunk and they have not ant problem as I saw. We also have 2 IPSEC VPN on WAN1, 18 SSL-VPN on WAN1 and 2 SSL-VPN on WAN2 (just to try). Emplyees connects to VPN and then to they PCs via RDP. Every day at 10.04 and 16.04 - I don't know if it happens every 6 hours.- some SSL-VPN (6 on 20 today) drop and SSL client must be restarted. It happen on VPN connected on both WAN (we moved 2 VPNs on WAN2 just to try). Today, At 10.04 some VPNs dropped, but not on mine that was the double of another in use (we created different user for each employee). I was also connected on the server waiting the hour with teamviewer but had no issue. I checked the server but I could not find anything strange. But the strange is that it happens always on same hour. Last week it was 2 years early, but always at :04 (we restarted it)
I tried also to send me firewall's log but we did not configure
properly the "send mail" so I just have some screenshot... I'm trying
configure it tonight (we are in lockdown so I could not access to the
firewall directly) to provide a right log but the button on monitor => log don't send me anything.
Does somebody has any hint?
@Cava
Regarding to this case,
Can I know if only establish SSL VPN tunnel without RDP session, will disconnect issue occur?
After issue occur, please private message the below information for check further
1. Please Go to My PC>Local Disk C
Collect "SecuExtenderHelper.log"
2. and then Go to My PC>Local Disk C>Users>select the file of account which you login
Collect "SecuExtender.log"
- 602 USG FLEX H Series
- 481 News and Release
