L2TP connecting but not assigning IP
bavaria
bavaria Posts: 32 image  Freshman Member
First Comment Friend Collector Seventh Anniversary
edited April 2021 in Security
I have an USG 110 with the newest firmware and I setup a L2TP VPN.
I have following problem, two laptops (both Microsoft Surface) are working perfectly with the VPN.
But with all other Windows 10 (1909), I have a problem. Within the Zyxel VPN monitor I can see that this PC's can connect. But they don't get an IP address.
And after a short time the PC's disconnect and get different errors, mostly 718 or 829.
I also tried the NAT regedit hint, but it doesn't work.
Do you have an idea?
  • bavaria
    Hello Zyxel_Jerry,
    sorry for the late answer,
    I configured the vpn as you mentioned, but I had the problem that it cannot connect on some W10 machines.
    I setup now IKEv2 with a certificate and it works on all machines from beginning.
    Thanks.
  • Zyxel_Jerry
    Zyxel_Jerry Posts: 1,406 image  Zyxel Employee
    Hi @bavaria
    Can you share the VPN settings (VPN connection and VPN gateway) on USG110 ?
    What is the L2TP settings on Win10?
    Do you have any AD authentication?
  • bavaria
    Hello Zyxel_Jerry,
    Thanks.
  • bavaria
    Hello Zyxel_Jerry,
    I configured the vpn as you mentioned, but I had the problem that it can't connect on some W10 machines.
    I setup now IKEv2 with a certificate and it works from beginning.
    Thanks.
  • bavaria
    Hello Zyxel_Jerry,
    Thanks.
