Unable to create or update Reports
Thierry
Thierry Posts: 2 image  Freshman Member
edited April 2021 in Security
Whenever I try to create a report, I get this message
"Unexpected exception: Direct assignment to the forward side of a many-to-many set is prohibited. Use widgets.set() instead"
The report is created but without any widgets enabled. And I receive empty reports.
Trying to update the report configuration leads to the same issue :
Deleting, recreating the reports doesn't solve the issue.
So I have been receiving empty reports for weeks now.
What's wrong with the config ?
Thanks for your help.
Thierry
  • Thierry
    Thank you ! It works fine now.
