vpn site to site
damianodec
damianodec Posts: 42 image  Freshman Member
edited April 2021 in Security
hi,
I need a VPN site to site, site A and B have USG40.
site A 192.168.6.x and USG40 192.168.6.254
site B 192.168.6.x and USG40 192.168.6.1
is it possible or have I to change addresses on A or B ?
thank you
  • Alfonso
    Alfonso Posts: 257 image  Master Member
    Hi @damianodec
    I do not think you can establish a VPN using yje same source and destination ip address range (I am assuming network netmask is /24).
    If ip address range of the sites are not overlapped, the VPN be configured.
    Another way to try to connect is to configure static NATs which will be done in (for example) in site A, and "undone" in site B. But i do not recommend it.
    Regards
  • Jeremylin
    Jeremylin Posts: 166 image  Master Member
    First Answer First Comment Third Anniversary
    Check this article to avoid local subnet overlapping problem.
    However, it could be managed easier if the network with different subnet.
    https://kb.zyxel.com/KB/searchArticle!viewDetail.action?articleOid=014715&lang=EN
    PeterUK Posts: 4,430 image  Guru Member
    If you subnet each site to 255.255.255.128 then it would work.
  • serverpal
    serverpal Posts: 29 image  Freshman Member
    thank you!
