GS2210-48p randomly stops sending Radius requests
Kevin_FT
Kevin_FT Posts: 4 image  Freshman Member
edited August 2022 in Switch
So I've noticed this a few times now.  Randomly on some of the 60+ switches I have had them become inaccessible from login (both webpage and SSH).  I can usually go into radius and disable the client then proceed to SSH into switch with the local creds.  But the only way to get the switch back to talking through Radius is to reboot the entire switch itself.
Logs on switch itself state that it does flip between the 2 radius servers I have configured then a no authentication message.
1 May 20 12:11:31 WA authentication: RADIUS Authentication - change RADIUS server from 1 to 2
   2 May 20 12:10:04 NO authentication: SSH authentication failure [username: Name, IP address = 172.xxx.xxx.xxx]
Firmware Version - V4.50(AAHV.2) | 02/27/2018
I haven't tried the latest firmware yet, This switch has also been up for 357 days, but this shouldn't stop the radius server.
Anyone else having experience this issue?  Is there a way to just restart the radius service without disrupting the site connected to this switch?  The external logging server never actually shows a radius request leaving the switch until after the restart also.
  • Zyxel_Lucious
    Zyxel_Lucious Posts: 283 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 1 - Nebula 25 Answers
    edited May 2020
    Hi @Kevin_FT
    For starters, it's recommended to upgrade to latest 4.50(AAHV.3)C0 which includes the new bugfix.
    As for your issue:
    1. What is the frequency of the "stop sending" symptom?
    2. May I know what RADIUS servers you are using?
    3. Could you provide the config (including AAA setting) for us?
    Zyxel_Lucious
  • Kevin_FT
    1. No direct frequency as I'd have to pour through daily config downloads to find out when that stopped.
    2. Microsoft NPS V10.0.17763.1
    3.
    hostname "GS2210"
    time timezone -700
    time daylight-saving-time
    time daylight-saving-time start-date second sunday march 2
    time daylight-saving-time end-date first sunday november 2
    timesync server 172.xx.xx.xx
    timesync ntp
    snmp-server version v3v2c
    snmp-server get-community XXXXXXXX
    snmp-server set-community XXXXXXXX
    snmp-server trap-community XXXXXXXX
    snmp-server trap-destination 172.xx.xx.xx
    snmp-server trap-destination 172.xx.xx.xx enable traps interface  linkup linkdown lldp transceiver-ddm storm-control zuld
    snmp-server trap-destination 172.xx.xx.xx enable traps switch  mactable
    service-control http 80 5
    remote-management 2
    remote-management 3
    remote-management 4
    remote-management 1 start-addr 172.xx.xx.xx end-addr 172.xx.xx.xx service telnet ftp http icmp snmp ssh https
    remote-management 2 start-addr 172.xx.xx.xx end-addr 172.xx.xx.xx service ftp icmp snmp ssh https
    remote-management 3 start-addr 172.xx.xx.xx end-addr 172.xx.xx.xx service ftp icmp snmp ssh https
    remote-management 4 start-addr 172.xx.xx.xx end-addr 172.xx.xx.xx service ftp icmp snmp ssh https
    syslog
    syslog type system
    syslog type interface
    syslog type switch
    syslog type aaa
    syslog type ip
    syslog server 172.xx.xx.xx level 6
    aaa accounting system radius broadcast
    aaa accounting exec start-stop radius broadcast
    aaa accounting dot1x start-stop radius broadcast
    aaa accounting commands 0 stop-only tacacs+ broadcast
    The one odd piece which leads me to believe that AAA requests are being sent is that SSH will accept the local logins with the radius client enabled, but no AD creds.  The webpage will not accept the local creds, or AD creds until I disable the client on the radius server, which will enable the local logins only.
  • Zyxel_Lucious
    @Kevin_FT
    From your config I don't see config about authentication (in AAA setup) and RADIUS server.
    Can you give me the complete config by PM?
  • Zyxel_Lucious
    edited May 2020
    @Kevin_FT
    We've tested locally with 2 RADIUS servers working with GS2210 and seemed working fine when flipping between servers.
    Maybe you should check if any abnormal log in the 2nd RADIUS server?
