Network slow after firewall change
sorry,
- is block client access to device via wan with any service....
but I need to keep vpn
For first question, Go to security policy, first rule wan to Zywall, service:NATT,IKE,ESP,AH, allow. Second rule,wan to Zywall, deny.
For second and third question, since the Client and server are on the same subnet, please try to enable the "Allow Asymmetrical Route" on the policy control, then check it again.
Dear Charlie,
There is another question.
After change firewall, sometimes, nslookup is Ok but fail to ping and access web by browser...how to check it?0 -
It seems DNS issue, did you ping IP address or Domain name?
Check this example,
https://businessforum.zyxel.com/discussion/4273/4g-network-slow-on-usg-60#latest
Dear Jeremylin,
After change router, some computer pop"select network location" sometimes.
It is not always happened.
Maybe per 1-2 months once...
Not all computer, but some....0 -
Not Always, but sometimes pop up when user start computer0 -
If the pop"select network location" appear, it's probably connecting to different routers or connect new network.
you can check this discussion
https://superuser.com/questions/236996/why-does-set-network-location-pop-up-every-time-i-connect-with-vzaccess-manage
There is one router only.
Client->switch-> USG110 router->internet.
There is no other router in network.0 -
On my environment, I did not see this popup page during connected with USG.
you may also tick "Treat all future networks that I connect to as public, and dont as me again" to avoid the popup page.
- 441 Beta Program
- 293 Service & License
