USG20W-VPN: Problems establishing Wifi connection / spontaneous reboots
  • thom_ko
    thom_ko Posts: 16 image  Freshman Member
    Hi @dudu,
    no I didn’t get a bugfix from ZyXEL so far. I‘m still on V4.35(ABAR.3) and am waiting for a result of the analysis of my logs.
    I‘ll post here if there’s any progress....
  • Zyxel_Charlie
    Zyxel_Charlie Posts: 1,034 image  Zyxel Employee
    @thom_ko & @dudu
    We are still investigating this issue, and any update, will let you know asap.
    Sorry for causing your inconvenience.
  • Zyxel_Charlie
    edited April 2020
    @thom_ko & @dudu
    Regarding to this case,
    I have private message firmware to you. Please have a check.
  • thom_ko
    @Zyxel_Charlie
    Thanks for your feedback. I installed the firmware you sent me via private message and copied the same amount of data which I did before (which caused the router to reboot). This time it worked without any problems. I managed to copy an amount of around 10GB without any problems.
    As while logging into my router I got the announcment for 4.38(ABAR.0) which was released recently, I also tested it with this version. I can confirm that 4.38(ABAR.0) still triggers the bug.
    When will the bugfix be part of the official release?
  • Zyxel_Charlie
    @thom_ko
    Since firmware v4.38 is ready, we would like to include this solution to next release.
  • janatajan
    janatajan Posts: 1 image  Freshman Member
    @thom_ko
    When will this fix be ready? I'm also experiencing the same issue. Client is furious and I have to buy another device to replace this USG20W-VPN so the one I bought few weeks ago is just a waste of money for me.
  • Zyxel_Charlie
    @janatajan
    Regarding to the USG20W-VPN issue, you can download the current patch from the link below
    Link:
    https://drive.google.com/file/d/1sgF6Je59SCMw0fVToSfUYcDykGLSHGD0/view?usp=sharing
  • Rigo
    Rigo Posts: 6 image  Freshman Member
    getting firmware installed, my kids keep complaining that wifi goes away and the only thing that get it live again is a power cycle.  I also have laptop cooling fan connected to USB just to make it cozy and we have to power cycle about twice a week... this started to happen about a year after purchase and I only update firmware when there is an issue... so maybe this patch v4.38 will do the trick
  • Rigo
    This is a big issue for little guys like us, we believe in ZYDEL products but quality control just has to be BETTER. Thanks Zyxel_Charlie for being here and helping us, really appreciated--its been a couple days since I installed V4.38(ABAR.0)ITS-WK19-r93724 from Gdrive link ;) and so far so good.
    At $200-250 20W price is ok, next up 40W $400, 60W $600 and so on just gets way out of reach for customers--and could you imagine if those models had firmware issues... ouch that would not look good on US and a quick way to look for other brand.
    I would like to continue to purchase and install the 20W but these issues related to firmware and Wifi just have to stop---either that or I am going to purchase non wireless box and install reliable APs as I was doing before.
  • Zyxel_Stanley
    Zyxel_Stanley Posts: 1,398 image  Guru Member
    Hi @Rigo
    It’s good to know it has fixed your issue.
    This fix will also include in next FCS version which will release at Q3.
