Signature Update not going out trunk order
So testing the USG 40 with IDP/AppPatrol Signature Service with uptime of over a day when you click update now for IDP/AppPatrol I can see it trying to get updates by OPT which will fail my trunk order is vlan443 1st then opt the Registration Status refresh works fine and goes out vlan443 just not the IDP/AppPatrol update when the USG40 has been up for over a day.
Hi @PeterUK
You can try to create a customize trunk interface first.
And apply the customized interface as default WAN trunk.
Then system outgoing traffic will through VLAN443 which you configured.
But I need it to be VLAN443 and OPT
How about when if fails to get update by one gateway it tries the next?0 -
Hi @PeterUK
You still can add multiple trunk object on system.
For signature update, you can select “VLAN443” as system trunk.
For traffic forwarding routing, you can add additional policy route and set next-hop as the other trunk object.
Ok guess thats good still it would be good idea to tell the USG what interface it should connect out of currently my VLAN443 and OPT trunk is working and updates are going over vlan443 it just seems to fail randomly and only trys to get updates by OPT.
Hi @PeterUK
It’s good to know it is helped for your environment.
Device signature update will use “User configured trunk” in default trunk selection.
So if OPT interface is one of member, then it will have chance leads fail. Since your OPT interface without internet connection.
The best setting is only setup “VLAN443” in “User configuration trunk”.
OPT does have internet it just the way its setup the USG for its self sends traffic and is expecting traffic only on the OPT where as a PC say 192.168.255.193 SNAT out OPT and expect traffic on OPT and or from the bridge WAN DMZ.Zyxel_Stanley said:So if OPT interface is one of member, then it will have chance leads fail. Since your OPT interface without internet connection.
Thanks0 -
Just thought I update this problem as there is a fix that this problem happened too for updating Geo IP and that is make a routing rule for ZyWALL to go out the give next hop.
update change source to any
- 222 Nebula Ideas
- 616 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
