Zywall 110 VPN access using port 4.
2»
    PeterUK Posts: 3,892  Guru Member
    edited June 2020
    It might be that your LAN1 IP/subnet and works IP/subnet is the same so change LAN1 on the Zywall110 to 192.168.0.1 as long as your works subnet in 255.255.255.0 then it should work and the two subnets don't conflict.
  • Alex_Family
    Alex_Family Posts: 8  Freshman Member
    Thanks. Im going to fully reset the Zyxel and start from scratch. Ill report back.
  • Zyxel_Stanley
    Zyxel_Stanley Posts: 1,397  Zyxel Employee
    100 Answers 1000 Comments Friend Collector Seventh Anniversary
    Hi @Alex_Family
    You can use L2TP wizard to auto-generates L2TP configuration on your ZyWLL110.
    You can reference to this FAQ
    After L2TP client established L2TP VPN tunnel, then should able access to intranet of ZyWALL110.
