Change the port for SSL VPN
PeterUK
PeterUK Posts: 4,386 image  Guru Member
edited July 2024 in Security Ideas
Change the port for SSL VPN so the SecuExtender can connect on another port other then 443.
0 votes
Completed · Last Updated
Support in ZLD4.64 and above version.
  • VS777
    VS777 Posts: 1 image  Freshman Member
    In the settings: system - www- https port, any port is selected.ведите свой комментарий
    So it does thanks but what about keeping www to 443 and SSL VPN to another port.
