XGS4600 - SFP+ Transceivers stop transmitting light
2»
  • B4RN_Mercer
    B4RN_Mercer Posts: 3 image  Freshman Member
    @Zyxel_Lucious
    Thanks for that however if that's the case please can you try to explain why the problem doesn't occur on the 52f variant of this switch line-up when we're using the exact same optics with it.
    Surely if we was buying unsupported transceivers then we should see issues across the xgs4600 range.
    Matthew
  • Zyxel_Lucious
    Zyxel_Lucious Posts: 282 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 1 - Nebula 25 Answers
    @B4RN_Mercer
    Our local sales will reach you and clarify the concern shortly, thanks.
    Zyxel_Lucious
