Subnet conflict..?
Gayanll
Gayanll Posts: 14 image  Freshman Member
edited April 2021 in Security
I recently connected a 3G modem to my USG 20-VPN. Now i keep getting this warning.
what should i do? I feel like my network just got a bit slow too.
thanks
  • jasailafan
    jasailafan Posts: 193 image  Master Member
    What are the IP address of the cellular interface and lan1/lan2/dmz/guest interfaces?
  • Gayanll
    Cellular interface having public IP by ISP 10.65.xx.Xx
    lan1 is 192.168.1.Xxx
    there is no Lan2,dmz,guest
    edited June 2020
    So you need to change lan1 IP to not conflict with cellular.
  • Zyxel_Stanley
    Hi @Gayanll
    Some of dongles have default IP address with 192.168.1.X.
    It has conflicted to default LAN1 IP address.
    Please try to change LAN1 IP address to other subnet and check if it has improved this situation.
  • Gayanll
    Hi @Gayanll
    Okey i will do like that.
    just curious can i change the dongle’s IP instead?
  • Zyxel_Stanley
    You can try to plug-in the dongle to your PC and check if there is Web interface for change IP address.
    But it may not support for all of dongles.
  • Gayanll
    So i changed my LAN1 IP address range.
    now its 192.168.2.XX as shown;
    But i still gets the same error
    "Subnet Conflict!! Please do not use 192.168.1.X. Cellular1 has been inserted Huawei unknown"
  • Gayanll
