Subnet conflict..?
Hi @Gayanll
The IP address of wan subnet and cellular1 are conflicted. So system pop out this error.
It means you have to change IP subnet of your WAN side network.
According to error log“192.168.1.X”, it has mentioned wrong IP address. It will fix in future release.
5
What are the IP address of the cellular interface and lan1/lan2/dmz/guest interfaces?
jasailafan said:What are the IP address of the cellular interface and lan1/lan2/dmz/guest interfaces?
lan1 is 192.168.1.Xxx
there is no Lan2,dmz,guest0 -
So you need to change lan1 IP to not conflict with cellular.0
Hi @Gayanll
Some of dongles have default IP address with 192.168.1.X.
It has conflicted to default LAN1 IP address.
Please try to change LAN1 IP address to other subnet and check if it has improved this situation.
Zyxel_Stanley said:
Hi @Gayanll
just curious can i change the dongle’s IP instead?0 -
Hi @GayanllYou can try to plug-in the dongle to your PC and check if there is Web interface for change IP address.But it may not support for all of dongles.0
So i changed my LAN1 IP address range.
now its 192.168.2.XX as shown;
But i still gets the same error"Subnet Conflict!! Please do not use 192.168.1.X. Cellular1 has been inserted Huawei unknown"0 -
Hi @Gayanll
5 -
Thanks0
- 434 Beta Program
- 173 Nebula Ideas
- 411 USG FLEX H Series
- 297 Security Ideas
- 43 Wireless Ideas
- 268 Service & License
- 416 News and Release
- 87 Security Advisories
- 4.1K FAQ
- 82 About Community
- 87 Security Highlight
