VPN2S Web GUI SSL Certificate
Hi Team,
I've managed to get upload my certificate on my USG60W and get it activated however I do not see an option on the VPN2S to change it from the default generated certificate to the one I have uploaded. I cannot delete the default one either.
How do I change this?
Hi @RCP
If you would like to change default HTTPS certificate.
You can go to Firewall/Security > Device Service > Certificate.
You can change certificate which you imported/generated on system.
5
Hi @RCP
5 -
Zyxel_Stanley said:
Hi @RCP
That seems to be the area but my certificate is not showing...
Any thoughts?0 -
Hi @RCP
According to this situation may come from your certificate incomplete path or without private key.
So it is not able to select in HTTPS certificate.
You may attach all of your certificates and send private message to me for further check it.0 -
I followed the same process I did on the USG60W. I could even upload my VPN2S certificate on the USG60W and it showed. Tried different certificate names and even removed the extension. It is not showing.0
- 431 Beta Program
- 2.6K Nebula
- 165 Nebula Ideas
- 6K Security
- 364 USG FLEX H Series
- 292 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 262 Service & License
- 407 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
