Connection check Disabled
Did you select the VPN tunnel before clicking the button ?
What kind of VPN scenario are you using? Is it site to site with dynamic peer? or IKEv2?
It would be helpful if you can take a video of the symptom of the issue on the monitor page of VPN connection.
Hi @dpipro,
The Connection Check button is grey out before selecting a VPN tunnel.
You could follow jasailafan’s instruction to share us related information if it is still unable to click.
@Jasailafan, Thanks
- 244 Nebula Ideas
- 6.9K Security
- 808 USG FLEX H Series
- 392 Security Ideas
- Threat Watch!
- 88 Switch Ideas
- 60 Wireless Ideas
- 7.3K Consumer Product
- 333 Service & License
- 541 News and Release
- 106 Security Advisories
- 5.5K FAQ
- 89 About Community
- 124 Security Highlight
ZCNE Certified
