My bandwith is slower out of the firewall lan ports, than it is on the wan side
try the following
https://businessforum.zyxel.com/discussion/4494/tip-for-getting-faster-throughput-on-usg-vpn-zywall
by TCP the most you might get is 350-400Mb as the 1000Mb listing for the USG60 is by UDP5
try the following
by TCP the most you might get is 350-400Mb as the 1000Mb listing for the USG60 is by UDP5 -
Thanks you PeterUK! That did a lot with my speed. But still I am a bit disappointed that the 1000Mb is just for UDP. I did not know that before i bought this FW.0
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
