Which USG Flex i should use
I raised my bandwith last month to 300/50 Mbit. Now the USG40 cannot handle this traffic anymore. Only 170-200Mbit, when i disable the security features and statistics.
But i will not use a firewall a simple route to get the bandwith. Which USG Flex i should buy to handle the full amount of traffic with security features on, Traffic statistics on and VPN Service.
But with TCP Traffic and not on UDP statistics in Datasheets - in a real world scenario.
thanks a lot
thanks a lot
Hi @Reinhold,
For device evaluation, it have many conditions need to take into account.
The follow information would be helpful to you for evaluating new network appliance.
BTW, based on your criteria, if you replace USG40 to Flex100, I believe there will be significant improvement.
Specification
https://download.zyxel.com/USG_FLEX_500/datasheet/USG%20FLEX%20500_1.pdf
FAQ
https://businessforum.zyxel.com/discussion/4588/usg-flex-frequently-asked-questions#latest
- 431 Beta Program
- 2.6K Nebula
- 165 Nebula Ideas
- 6K Security
- 364 USG FLEX H Series
- 292 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 262 Service & License
- 407 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
