Nat port does not work
I'd like to active xampp SERVER to my host ip 192.168.8.port 20200
I'm trying all internet guide and video but nothing.
in source IP I tried WANIP and any (in all interne guide NAT there are original IP and mapped IP, here is source IP, external IP and internal IP), in port mapping I tried Port (like above image) and services
any help?
thanks
Hi @serverpal
You would like to forward 20200 to internal server.
So it have to also add policy control rule for allow 20200 from WAN to LAN.
Can you make sure your service port is 20200? (HTTP default port is 80)
And also source IP address shouldn’t WAN1 IP address….except you already known client IP address.
hi @Zyxel_Stanley
thank you,
I just can't fix it.
ISP ROUTER ports 20200 connect to 192.168.1.237
ISP router 192.168.1.1 connect to USG40 WAN1 192.168.1.237
USG LAN1 192.168.8.1
my xampp server 192.168.8.7
inside lan from pc 192.168.8.50 by browser I type 192.168.8.7:20200 and I see xampp dashboard (web server works inside lan).
but nothing, from outside (http://xxx.xxx.xxx.xxx:20200) I cant see my server web
Can you put you ISP router in modem mode/bridge mode so the USG has the WAN IP?1
Hi @serverpal
Your USG is behind the other NAT route. (double NAT)
You have to create port forwarding on ISP router first.
External IP:XX.XX.XX.XX(Public IP), Mapping IP: 192.168.1.237, External Port: 20200, Mapping port: 20200.
Of cause you must make sure ISP router is able forward traffic to USG.
On USG:
NAT Rule:
External IP:192.168.1.237, Mapping IP: 192.168.8.7, External Port: 20200, Mapping port: 20200.
The policy control rule can configure as the same as I posted to you before.
hi,
my isp router is managed from my ISP company (I cant to access it).
NAT SOLVED,
ISP company told me that open port has about two days of work and now I can connect to my server.
Thanks to all, you have been very helpful !
- 435 Beta Program
- 176 Nebula Ideas
- 425 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
