USG60W Port Forwarding
I have recenty purchased a USG60W and am trying to set up port forwarding to a L2TP VPN server sitting on our LAN. Unfortunately I have been unable to get the port forwarding to function at all. The wizard appears to set things up correctly but the router does not allow access from outside the network. I have tried to set up manually but still does not work. Even a basic PPTP VPN won't work.
Any ideas? Am I missing something?
Are you doing double NAT or does the USG 60 have the WAN IP?
Make a group with the following and make NAT rules as well to the given server and a policy control rule with this group.
PPTP_TUNNEL or GRE
ESP
PPTP
IKE
PPTP
L2TP-UDP
The USG 60 has the WANIP0
Have tried what you suggested, which I am pretty sure I did yesterday, but it still does not work.Very puzzling. On L2TP it keeps coming back saying there is a processing error?0
Hi @Saloh,
One more port need to be added in L2TP behind NAT scenario.
Did you add port NATT(UDP 4500) in NAT rule service group?
- 243 Nebula Ideas
- 6.9K Security
- 796 USG FLEX H Series
- 391 Security Ideas
- 88 Switch Ideas
- 59 Wireless Ideas
- 7.3K Consumer Product
- 327 Service & License
- 530 News and Release
- 104 Security Advisories
- 5.4K FAQ
- 91 About Community
- 122 Security Highlight
