Invalid state detected DROP (for VPN user)
we have "Security Policy Control - Invalid state detected DROP". Reconnecting not solved the issue. Only Zyxel reboot solved it. After Zyxel reboot all worked fine again. The USG ran for 3 weeks before restart without issues. USG110, fw V4.35(AAPH.3)
What exactly means "Invalid state detected"?
Hi @Martin_Kuchar,The USG is stateful firewall. Packets will be dropped (“Invalid state detected”) if packets with invalid headers, checksums, TCP flags, or ICMP messages (such as a port unreachable when we did not send anything to the host), and out of sequence packets.Does the log occur in specific protocol/application when running SecuExtender?0
Zyxel_Cooldia said:Does the log occur in specific protocol/application when running SecuExtender?Hi Cooldia, thank you for clarification about the internal firewall. The log occur typicaly when expected - when unwanted communication come from WAN, but as described, we got it also for two users at one time. One was logged in with SE for some time without issues, but from one moment, he lost internal connections and the log occures. The second user tried to mimic the situation, logged in also with SE from another place in internet, connection was OK, he received IP from DHCP, but cannot reach the internal LAN resources. The same issue in the log. After restarting USG, everything was solved. Looks like problem in TCP stack after 3 weeks of running. But connecting to USG from WAN and also accessing inet from LAN was still OK. Only the firewall in internal communication was problem.
Hi @Martin_Kuchar,
We may need to further check what had been configured on your device.
Can you send me your configuration file via private message?
Hello @Zyxel_Cooldia,
I have a similar issue on my USG60 with an IKEv2 VPN Tunnel. Is there already a solution? I've deactivated the abnormal tcp flag detection, but that had no effect.Is there anything else I can do?
Hi @lwi
Does the symptom always exist after client established IKEv2 successfully?
You may make sure local policy and Configuration Payload setting.
-> Local policy 0.0.0.0 is meaning all of client traffic will pass into USG directly
-> Pool IP address shouldn’t overlap to any Interface IP subnet.
And also make sure IKEv2 Pool has routing rule for Internet and Intranet.
If the symptom is random, you may try to upgrade firmware to 4.60P1.
It has fixed VPN routing stability issue.
I have a very similar issue since about 5 days.
User on the Lan get a DHCP from our local server. They can ping each other but can't ping the router (Zywall E310) and can't ping an internet IP. Not all user are impacted about 5 to 10 each morning. After some time and some useless action on the PC, connectivity get back …
On the log we see many message saying :
debug
invalid state detected, DROP
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
