LTE Firmware update SBG 3600
in SBG Series
The SBG3600 LTE performance seems to be much lower for me than it should be. Are there any firmware updates? My current firmware details...
Main Current Firmware Version: V1.00(AAKO.9)
WWAN Current WWAN Package Version: 1.15
LTE Current Firmware Version: ALT3100_04_05_06_10_B8_LO
Thanks & regards,
Vinod Menon.
Sign In to comment.
The SBG3600 supports LTE CAT3 with its theoretical maximum download speed as 100 Mbps. This product has been released for about 5 years; as mobile technology and products are developing fast, the SBG3600's LTE technology may not be as competitive as the other new products, e.g. mobile phones or LTE-only routers. However, it still has an edge over the other fixed line routers as it provides another fail-over option for the router.
I will send a private message with the latest LTE firmware. It may enhance the LTE speed.
Regards,
Bob
Thank you very much. Really appreciate.
regards,
Vinod M.
Can you send me the last LTE firmware (For FRANCE) ?
Thanks a lot !
Please check your inbox.
Regards,
Bob
Please send that firmware to me as well. Thanks!
