SSL VPN client for Linux
secu_guest
Any plans to implement SSL VPN client for Linux?
Hi @secu_guest
Welcome to the forum.
I have not tested openconnect (open software to connect to VPS SSL networks) to connect to a zyxel device, but I suppose it could be used ...
I suggest to try. Do not hesitate to contact me if you want us to do it together.
Regards
Hi @Alfonso,
I am trying to use openconnect with the ZyXel ssl vpn. I would be glad of your support for this.
Have you implemented this already ?
Best regards.
Hi,does anybody succeeded in connecting to a Zyxel SSL VPN?I'm trying but obtaining:'XML response has no "auth" node
Failed to obtain WebVPN cookie'Am I missing some configuration?Thanks,Fabio
Would also be interested in a solution.
Thanks, Torsten0 -
Again if I could add my input. I also get the XML response has no "auth" node error. Massive issue that there is no Linux support0
- 221 Nebula Ideas
- 610 USG FLEX H Series
- 53 Wireless Ideas
- 299 Service & License
- 483 News and Release
